Fuel injectors special tool required?
Hi everyone, is that special tool for the fuel injectors required to remove/install on the 1.6 ecoboost? Also I noticed another special tool is required to install the damn teflon injector seal. Is installation possible in your own garage without those tools? I was just going to wiggle out the damn injectors if I could and have them cleaned, but now that teflon seal has me all screwed up.
Sent from my moto g power using Tapatalk
Rocketst
Just wiggle em out bro. I've taken them out at least 5 times since the start of my build.
Sent from my IN2019 using Tapatalk
D
What did you do about the teflon seal?
Rocketst
You can remove the special deal with a pick but it may be easier in the end to just buy new injectors instead of cleaning. There's a chance that seal may not seal anymore after replacement. As far as removing them, it's easy. Your doing more work than I did. I just bought injectors did ebay from a scrapped car for half the price and popped em in.
PunkST
My wife and i found an injector seal tool on ecstuning.com. idk if itll work with fords, but its definitely handy with her gti. ( even though the new injectors came with new seals, we picked up the tool.)
D
Thank you for the suggestions and advice. Pulled the injectors earlier today and on one of the injectors I can't even see the damn holes on the pindle even after spraying with cleaner. I still have 0 check engine lights so I'm hoping me servicing the injectors can clear up any possible leaks that may be occurring.
