Fuse 24 (Emissions System) keeps blowing
Check the Boost solenoid wiring for any nicks ir rybb through*
Turbodhi
Thread Starter #22
Everything is tight/jumbled up under the intake tract and things can rub against each other causing exposed wires or vacuum leaks, for example. Glad you dug in and found the exposed wires and it seems to be working. Sounds like you fixed it. Let us know if it's permanent or something crops up down the road.
I've been cruising around for the past week or so without a single issue so that looks like it did the trick.
