HELP Cobb intake on 2018 FiST confusion!
Hey all - I've been interested in picking up a cobb intake, and found a used one close to me - but do I need anything else for this set up since in my 2018 FiST? Tried reading into understanding the evap related codes and got more confused. Do I need the mountune adapter for this or other intakes if I have not touched anything in the evap system? Any help would be awesome!
Is it for my'16-'18? If not you'll need the whoosh evap fix kit
Just switch the evap harness to a 2014-2015 system while you’re swapping the intakes. It will add all of 4 minutes to the job and is less likely to fail than the 2016+ purge valve. .
