How to get vehicle emissions monitor in ready state?
CSM
Cleveland, OH, USA
I'm in a county in OH requiring emissions check now. Mods are in signature. Custom tune by CPE, running defouler on the DP.
Having a tough time getting the emissions monitors to read in ready position. Specifically, catalytic converter and evap seem to be the problem ones.
I've tried resetting KAMs and ECU with no success, even after driving ~1,000 miles to/from SC
Any other upgraded turbo peeps have recommendations?
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
First remove the tune (reset to OEM) then post what monitors are not being set.
I have never heard of a tune effecting the EVAP system so you may have a fault there.
In addition if you have over 60K miles on the car, you may have a faulty O2 sensor, CAT, or both.
Clint Beastwood
Laguna beach
It’s based on drive cycles (readiness monitors) not just miles. Driving a few weeks of regular day to day does the trick usually. Your tune might have some things set to ignore that could prevent the readiness monitors.
London, ON, Canada
In a regular, untuned car, normally you can get the checks to complete after say 20-60 minutes of driving and 2-3 engine starts. I believe most e-tests will allow you to have one or two checks not "ready". For evap, you also must have a certain amount of fuel in the tank, I believe typically >1/4.
Ford ST
Pleasant Garden
The tune could possibly be a problem.
On the other hand what type of downpipe are you running? It may be difficult for that monitor to set. Take the tune off and go from there.
