- Member ID
- #2745
- Messages
- 665
- Likes
- 180
I am on the hunt for a nice LSD, and I came across the MFactory Helical LSD an an option.
http://focusonperformance.com.au/mfactory-lsd-helical-limited-slip-differential-st180/
Helical:
* Will lock and apply equal rotational speed to both wheels
* Will distribute torque to both wheels, however not 50/50 ? depending on type the ratios vary
* Locking on throttle but requires both wheels to be on the ground
* Helical LSDs uses gears and not clutch packs, hence do not require servicing or anything to be replaced. * Maintenance would be similar to an open differential
* Often helical differentials react much quicker than viscous LSDs and do not fade with use as they use gears
* Great overall type of LSD but very limited aftermarket choices
I found a us distributor who currently list them for $699 USD, and from what I have read MFactory is who Honda utilizes to build their race transmission components. Toyota too.......
I made contact with a representative via their FB page, and I have sent an inquiry asking a few questions such as what their Fiesta ST 180 LSD can safely handle power wise.
I have also inquired if they might also be able to offer a taller final drive gear, since they do manufacturer final drive gears for other makes and models.
Our current FD gear is 3.82:1 and with 23.77" diameter tires and a 7000 rpm redline, 2cd gear at 63 mph, 3rd at 95, 4th at 126, and 5th at 158.
With a slightly taller 3.62:1 FD gear and all else equal, 2cd gear should be good for 67mph, 3rd at 101, 4th at 133, 5th at 167, and 6th gear is aero and power limited...lol.
I don't know anything about what all I am asking for, but with an uprated quick spooling X37 and roughly 280 whp/wtrq, I don't think a slightly taller FD would hurt if I am already inside the transmission and replacing the differential.
Thoughts?
Helical:
Thoughts?
