About 3 months ago, I did a brake service (Pad/Rotor). Everything seemed to be great, but a few days after install, a noise showed up from the front of the car. It would be occasionally audible while straight, but was exceedingly apparent once turning left more than 90 degrees on the wheel.
Because of this, I inspected the brake system to the best of my abilities. This included bolt checking, removing pads, removing rotor , removing caliper. There wasn't anything lodged anywhere, rotors weren't gouged, and the pads seemed to be breaking in ok.
After some research I saw many topics on what items can cause noise up front, but I can't narrow it down. Tried torqueing the front hubs back to 188 lbs, and it seemed to go away for a few days, but it is back and seems to be worse at this point in time. havent checked top mounts, but my Rear Mount is the Whoosh RMM, and it is torqued/hasnt loosened.
Forum posts read:
https://www.fiestastforum.com/threa...and-acceleration-help-2013-st-75-000km.18869/
https://www.fiestastforum.com/threads/grinding-noise-when-turning-left-and-hard-acceleration.27350/
My videos of noises for reference:
LEFT:
View: https://youtu.be/YfpqS9g4ixw
RIGHT:
View: https://youtu.be/osJh5mFl0O4
Forum posts read:
LEFT:
RIGHT:
