Odd front end creaking after Pierce 6pt crossmember install
alexrex20
Spring
Recently installed a Pierce 6pt crossmember on an otherwise stock 2017 FiST, and I'm now experiencing a very odd creaking on sharp steering inputs that tend to twist up the frame. It also happens when turning into an inclined parking lot or driveway. It feels like maybe the 6pt bar has stiffened up the front lower end of the car and now the rest of it is twisting more than before. It almost sounds like it's behind the dash but also sounds like it's a bit deeper under the hood.
It has me confussled. It does not sound like typical suspension noise like sway bar end links or strut mount bearings or tie rod ends... It really just sounds like creaking, but I can't figure out what would cause it.
It doesn't happen over bumps and not even that often. And it didn't happen before the brace.
Solution: more Pierce braces?
Chino Hills
If you shipped the step of lowering the vehicle slightly before torquing the bolts down to the control arms this will cause that exact same noise you speak of. Or not putting enough torque to the bolts!
A
alexrex20
Spring
Y'all two are exactly right! Well, you're right about insufficient torque. I did lower the car Before I tighten the lower control arm bolts. I thought I really cranked down on them but it was such an awkward angle that I must not have. In fact, I know I did not because I just finished properly torquing them with the car on ramps. They were definitely loose LOL
