- Member ID
- #8858
- Messages
- 94
- Likes
- 38
Hey everyone. Recently I was backing into my garage and hit my right side mirror and pushed it forward. When I parkedI saw that it had a gap underneath it. So I took it apart and nothing appeared broken. However, there is a little black plastic cap that sits on one of the mounts on the inside of the mirror assembly and it looked kind of chewed up. So to be sure nothing was broken I took apart the driver side and it looks identical to the passenger side. And that little black piece also was damaged on the driver side and to the best of my knowledge it has not been disassembled. I cannot for the life of me get these things to tighten up without gaps. It doesn’t rain that much here in Arizona but water can still get in there when I wash it and start rusting stuff and causing other problems inside the door panels. I tried to look for a part number for that little black plastic piece and so far no dice. Any suggestions on remedying this would be greatly appreciated. I’m half tempted to go to the dealer and see if there’s someway I can get it repaired under warranty.
