P2282 and P0507 after fmic
Had one clamp seem a little weird when tightening it up, but seemed ok.
Well now I have these codes and that’s what I’m betting on.
Anything else I should check before I take the bumper back off?
P2282 leak between throttle body and intake valves. P0507 fault in idle control system. I would go back in and recheck your work. Sounds like unmetered air is entering the system. Probably that weird clamp.
Commando81
sorry I forgot to update this.
Turns out the hard vac line that runs across the front of the engine past the cooling fan rubbed on the fan and wore a hole in it
