random high rpm-like noise when shifting after FMIC install?
Los Angeles, CA, USA
Not sure if I'm going crazy, but I installed a cpe FMIC on my stock tune 2019 FIST and am now randomly hearing an odd sound when shifting.
I've had 3-4 times over a couple weeks when I'll be upshifting from 2-3 or 3-4 and when I step on the clutch it'll sound like the rpms shot up like as if I pressed the gas in neutral, instead of being quiet like it is 99% of the time. Foot is not on the gas. I wasn't able to see if the RPM jumped/surged so not 100% sure if it is RPM related. I also can't reliably recreate this issue - it's only happened a handful of times when I wasn't expecting it.
Any obvious reason a cpe/aftermarket FMIC on a stock tune could cause this noise when engaging clutch during upshifts (I think it was while aggressively driving, so 5k+ rpm)? I never had this sound while shifting before the aftermarket FMIC.
XR650R
Eerie
Doesn't seem like that would cause anything. I'd try to reproduce the sound and check the tach to see if it is revving.
