Ride height adjustment vs toe
Grubbenvorst
Hi,
A long time ago I made the upgrade to a set of BC coilovers. After that i had the car realigned since the toe was way out due to increased negative camber.
Now, i increased the ride height since i was facing too many issues getting the car in/out of underground car parks with steep inclines.
I'm wondering if i should get my wheels aligned again. I noticed wear along the inside of the front tires, but this could be due to the camber setting.
Does messing with ride height have consequences for toe on the FiST suspension?
SFV, So.Cal.
Anytime you change the ride height in the front of a car you will change steering geometry.
Therefore you should always have your alignment checked or adjusted.
jeffreylyon
Pittsburgh
Yes, the toe changes with ride height. I'm pretty sure that raising the ride height is going to result in more toe in.
T
Grubbenvorst
Thanks for the feedback, will have it checked when in a couple of days when i change the tires. What i dont understand is that this would aslo mean the car should (inherently) have bump steer, but thats something i never noticed tbh.
This would mean increased tire wear on the outside, thats not what I'm seeing.
jeffreylyon
Pittsburgh
All cars that don't have a tie rod that swings on the same arc as the LCA have bump steer.
No - tire wear on the outside means that you don't have enough negative camber (and you drive like a maniac or have too much toe). Tire wear on the inside means that you have negative camber and too much toe, in or out.
