Seibon CF Hood Installment
Santa Rosa
So for those who installed a Seibon CF hood. What did you run into along the way?
Couple things people informed me about.
Washers - You have to buy Focus Windshield Washers
Fitment - You may have to cut and sand some of the hood to fit correctly..
All true?
DvC
Surprise
All true?
i didnt have to any of those with either carbon hood i had. you should be fine to remove the stock one and replace with the new one.
Pete
San Diego
I have installed three hoods and the only thing was all three needed 4 washers for where the hood bolts to the hinge on both the driver and passenger side. I do not know if they updated the design but that is what I have experienced when the hoods first came out.
Andover
why are folks putting on these hoods? is it due to the stock ones getting damaged and this is a less expensive replacement? How well does it take paint? Are you matching the body color exactly?
^^^It's a (somewhat) expensive way to drop ~10 lbs. off of the nose (and at it's highest point for cg ;) ) of these cars.
Some like the aesthetics of the carbon weave pattern as well, and some HAVE painted them.
