Tap into ignition power source?
Where is the easiest place to tap into an ignition power source without tearing apart the dash?
I have a dash cam currently wired into the 12v plug in, but it is constant power if the vehicle is on or off. So if I forget about the camera, it will just run all night. It draws nothing for power, so I just need a source that goes off when the car is turned off too.
JPGC
You can tap off the fuse box behind the glove box with a add-a-fuse. Like this...
CanadianGuy
P
Sweet, thanks guys!
it actually does turn off after about 15min after the ignition is off (if you open up your door, it'll power up again)
P
Not what I've found with my 12v outlet... my dash cam ran for 6 hours on a test to see if it would turn off
