Timing Belt
V8Pinto
SE Missouri
I know its an interference engine my thought is can I just pull head have repaired reinstall head and all good or does it usually damage pistons too....Thanks
slopoke
Livermore
Yes, the pistons will be damaged as well and If a rod breaks, you could also put a hole into your block. Not something to put off, it'll cost you more in the long run. You are going to have to replace the belt if it breaks and now you add the costs of the components that were damaged, because of the broken belt. Do you feel lucky?
V
V8Pinto
SE Missouri
Thanks slopoke, it already broke just wasn't sure what kind of damage it did when it breaks again thanks
