Tips for COBB Exhaust Hangers
Murray
Ordered the COBB exhaust hangers, took 45 minutes and messing up my hand and forearm muscles just to do the rear one. Popped off oem ok with a flathead, then sprayed wd-40, which sucked trying to slide cobb on. Ended up spraying shit ton of windex and wiggling and pulling to get in on. Anyone have tips to tackle the other two? thought it would take 10 minutes to do all tree, LOL! Any help is appreciated.[8]
Clyde
Honestly, I don't remember them being that hard to push on. But I believe I gave each of mine a shot of red or white lithium grease. You could also try squeezing them on using a large set of channel locks.
SaltFiST
Murray
Ya I used channel locks it took minutes.
Dammit, forgot to mention that i eventually did use channel locks, and that is when i was able to pop them on. still took a minute though. Channel locks are the key then. Plus, i think i have the upper body strength of an infant, that doesn't help.
St. Clair Shores
I used white lithium grease and a hammer. Spray the grease on the actual hanger, and the part the hanger goes on. it slides on like no tomorrow, wipe off the grease with a rage, and bam. 10 minutes.
SaltFiST
Murray
Awesome, thanks man.
koozy
Los Angeles, CA, USA
w40 and my hands worked for me. they're certainly tougher to get on than the soft OE hangers, but doable with w40.
CanadianGuy
Southern Ontario
Shot is silicone grease in spray format, and muscled them on but that was on the Mountune CBE which have an arrow head type hanger bracket making it ultra easy.
Orange county
Put some lithium grease I have for the bushing on my mustang on the hangers. Had 3 of them done in 30 min. Is there a reason Cobb doesn't provide 4? I did the farthest front one (because my downpipe doesn't have a support bracket anymore) the middle one and the farthest back but would really like to replace them all....
CanadianGuy
Southern Ontario
I left the one closest to the the DP the stock one. My though was the engine rocks and a softer hanger along with the flexible pipe in the DP will allow a little more movement instead of flexing somewhere else in the DP.
Anyone wanting 4 order the FoST kit. Its 4.
Eastern
Just wondering what the specific benefits over stock are that the Cobb hangers bring to the table...I have an exhaust on the way but did not get the Cobb hangers. Wondering if it is a necessity....
Santa Fe
They're made of urethane so they don't flex. The stock hangers are like wet pancakes and allow the exhaust to shift and bang under hard driving.
DP03
Owings
Yea, this bothered me. Cobb is known for its quality products. To include 3 hangers on a car that uses 4 is stupid. I think it was an oversight on their part that they won't admit. I have almost all Cobb aftermarket stuff, but this was disappointing. I asked them for the 4th and they said sure, for $15.
Zissou
Charlottesville
Can we use the twist in hanger on our cars? The Focus one has 3x 2 hole hangers and 1 twist in hanger. If we can then I'll probably go for that.
http://www.cobbtuning.com/products/exhaust/ford-focus-st-exhaust-hanger-kit
J2FoRS
Central
My exhaust only has 3 hangars anyways. The front most one at the DP isn't even load bearing. So the Cobb 3 pack was perfect for me.
Orange county
If you have a downpioe that no longer mounts to the chassis like stock then it will be load bearing :)
