Since a closeout they might not be able to do this but I called about a different wheel not that long ago and I could order just one wheel, place it on the hub, did not clear, send back no damage, full refund or order the rest of them.
Why I went to 4x100!!!!
I just did another search and found a new wheel I like, Miata fitment as I have 4x100 hubs and run 15x9 for the track but have been looking for the right 15x8 for the street.
I always loved this wheel style and have had many.
Low pressure cast, flow formed(same as roll formed which is great) 12.85 lbs, $142 each. I would have to order one to see if it fits over my BBK and these should be a bit concave, probably the picture of the 7 or 8" wide up on the site for now.
The 8" +35mm is listed at 12.1 lbs, $138 each.
This one is available in 15x8 , low pressure cast, not sure if flow formed but still great, 12.1 lbs, $149 each and looks like it might fit right over my brakes from the picture.
There are some incredible values in 4x100, 15x7, 8, 9 and even 10" wheels that are flow formed, low weight, can handle all out racing and not cost a fortune.
Note: Tirerack has not always been spot on with their weights but usually pretty close.
If you are staying with 4x108 then TD from PCA has some of the best options.
Rick
