Transmission Blow'd Up on Track
Fusion Works
#62
Amen to that. It was working fine, now its not and I have to deal with it. This makes me mad.
cidsamuth
Thread Starter #63
Picked up the new transmission and got it bolted in, post LSD and 4.3 final drive install. Now to put everything back together.
There was extra cost for the 4.3 based on the troubles @Fusion Works described. All in all, adding the 4.3 to the labor/parts cost of the LSD swap probably cost me another $1200ish …. I don’t know I would do it again.
Fusion Works
#64
Looks like they used Honda-bond to reassemble the case. Glad its back in hand.
cidsamuth
Thread Starter #67
Transmission install done. A couple test drives revealed no problems with it, though it’s tighter and slightly notchier than the old one. An adjustment to the Coolerworx helped that a bunch. Will report back after track work next month.
@Fusion Works Did you have your tune adjusted with the final drive change? The only kooky thing …. RPMs hang a bit …. and even jump up …. when you push the clutch pedal to the floor in higher gears. I wonder if the ECU is confused.
Fusion Works
#68
Not that I know of. Pretty sure I put that gear in while I was still on a stock turbo and the standard Tune from the Mountune parts kits.
cidsamuth
Thread Starter #69
Fusion Works
#70
Who was your tuner?
I can't say for certain Randy didn't change my tune for the 4.06. I am pretty sure I told him I had that and I have no rev hang issues. I don't really understand how a final drive swap would cause rev hang.
cidsamuth
Thread Starter #71
Who was your tuner?
JST. I’ve already sent him logs and would expect a response tomorrow.
Pretty sure the 4.3 confuses the ECU because of load tables. Will see.
#72
If there are no codes it may be intentional. There is an explicit warning against powering off without first letting the ECU return the engine to idle. I'm stock software/hardware and have only seen this after aborting a hard pull.
Fusion Works
#73
That warning has nothing to do with this specific problem. The warning refers to hard cutting the turbo and oil pressure going to the turbo bearings. 125K rpm without oil pressure will not end well for the bearings.
cidsamuth
Thread Starter #74
Yea, I think there is confusion. The only thing happening here the RPMs are hanging and evening jumping up when I disengage the clutch. Particularly in higher gears.
Fusion Works
#75
The hang is weird, but the idle increasing with the clutch pedal should have nothing to do with the final drive. Be interested to see if the tune changes it.
With your limited driving can you tell the final is a lot shorter?
#76
I disagree. You're interpreting this in absolutes. LOWERING the oil pressure at a time when turbo RPMs are high doesn't help the bearings.
There is no confusion. As mentioned, I only see this "rev hang" if I cut throttle on a hard pull.
cidsamuth
Thread Starter #77
Look at the first post of Jabbit’s thread I dropped above. It’s exactly like the YouTube video he linked, and he edits that first post to state that revising the tune to account for the 4.3 was the solution.
Fusion Works
#78
A turbo doesn't need that much oil pressure, the galleys are tiny. Ford and common sense just doesn't want you shut the car down after running the turbo hard and potentially hurting the turbo bearings and not flooding oil through the housing to remove the heat. Rev hang was not done because Ford wanted oil pressure for the turbo.
#79
Oil is also used for cooling and flow rate is an important component to that cooling.
Fusion Works
#80
Agreed, still limited to a .125 or smaller oil gallery feeding the oil into the turbo and gravity draining it away.
