transmission bolt pattern info
does anybody have a transmission bolt pattern drawing with measurements? thank you!
There are 2 bolts, 1 near the oil filter and cooler right by an oil line is 48Nm. The second one right above the CV axel 40Nm. The test of the bolts around the bell housing (5) 48Nm.
B
I'm actually looking for an actual blueprint with specs because I need the details.
