Trouble Code Won't Clear
I had a new PCM installed on Friday and before I left the dealership I was informed that I'd have the check engine light on until the electronics "relearned" something relayed to the PCM. Well, the check engine light is still on. The trouble code is P0315 - Crankshaft Location Variation System Not Learned. I tried resetting the ECU/clearing the code with the Cobb AP as well as leaving the positive wire off the battery for a few hours but the code still will not clear. Can anyone help me, please?
Sugar Hill
Supposed to unhook the ground not the positive. I'm sure the AP would have cleared it though.
timmytoast
Well I'll unhook the negative then. And yeah, I thought the AP would've cleared it. I'm going back to the dealership tomorrow.
Austin
There is a specific relearn procedure with the OEM scan tool for this that will need to be performed at the dealer. I believe it's something like neutral relearn, etc.. They should know how to do it, takes about 2min!
Cheers,
Braden @ COBB
timmytoast
Cheers,
Braden @ COBB
Thank you! I want to load the tune from the AP to my car but need the trouble code gone.
SFV, So.Cal.
BTW,
Removing the battery cables on an OBD II car will not clear codes.
It does nothing to the ECU but set another code.
With the only exception of setting it back to an unlearned state.
Codes can only be cleared with a scan tool.
I have a SnapON scan tool and I do not have anything like a neutral relearn feature.
But I do not have the latest software update, maybe it is something new.
Dave
