Turbosmart BOV Help!
Toa Alta
Hi. Well i just installed the turbosmart bov ive been setting it on the softest setting. Its to the point that if i loosen a bit more it will be past the seal ring. Ok the issue I'm having is turbo surge. That wutututut sound every time I release the throttle. I replaced the included hose with a bit wider hose with no success. I. Used thread seal on the fittings and everything is sealed correctly from the map sensor all the way to the bov. I'm running out of options. Any ideas on how to fix this issue??
twolf
Canton
What happens when you're WOT and then lift off? A nice pshhhh or "surge"?
Having a little flutter at partial throttle isn't a big deal at all.
O
Toa Alta
Ive been making the spring softer. If i unscrew it a bit more it would be past the seal ring.
Miami
Don't make it softer....turn it the other way.....
Like 2 or 3 full turns to start.
Raymore
twolf:
What about at lower rpms? say you're in 2nd/3rd gear 2500-300 you happen to let off?
