I saw the other day my water pump pully was wobbling. So I decided it's maybe time to change the pump. I looked at some of the options and it seems the motorcraft pump and gates pump uses a plastic/composite impeller while some other aftermarket ones use a metal impeller. What are your opinions on the type of impeller? I'm leaning towards trying the metal impeller. A metal impeller would seem to be more resistant to heat deformation and long term fatigue failure compared to plastic. The only downside i see to using metal is that it could potentially chip and metal could go through the engine coolant lines and cause catastrophic engine failure? But then again, turbo turbine and compressor wheels are metal. It seems like Ford cheaped out on the design of the water pump and a metal impeller would be the way to go.
