What’s missing from my trunk?
Pittsburgh, PA, USA
I just bought my fiesta this month. I thought the trunk looks a bit bare, but not sure what it is missing because there is a mat there. I just thought it was odd that the body was exposed under the seats.
Can anyone tell me what’s missing? And why the current mat won’t cover the body under the seat?
Ford ST
Pleasant Garden
You're not missing anything you can place it at two different heights. You have it on the lower setting I keep mine on the higher setting, so I can store stuff underneath of it.
D1JL
Administrator
SFV, So.Cal.
It was really designed to fit the full size spare and still set flat.
I prefer mine in the lower position.
Ford ST
Pleasant Garden
What are you trying to say? I have always had it on the upper level. I probably put a hundred pounds of groceries on it every Saturday.
I can store things like a first aid kit, jumper cables, and so on and still have a clean looking space. I hate clutter.
D1JL
Administrator
SFV, So.Cal.
If you put the board in the lower position, the board actually sits on top of the full size spare tire provided with the ST and not flat on the metal trunk floor, as in the non-ST Fiesta, that uses a space saver spare.
I don't use the full size spare tire so I don't have this problem.
D
Pittsburgh, PA, USA
Thank you for the clarity!!
Broward county Fl
This could be a trick question, like which beer am I missing. :cool:
Seriously mine has been at the lower setting since day 2 of ownership.
Florence, KY
I always keep mine on the lower setting. I also did this at the dealership when I was testing to see how well my son's stroller fit. The sales guy looked at me like I keyed the car or something and immediately "fixed it". Had to 'splain that I didn't break the car.
babyivan
Queens
DITTO!
I have managed to fit everything I need underneath the false floor. I like that clean trunk look as well. I had a pic of my setup, can't find it though. I will have to snap another pic and post it on here.
Ford ST
Pleasant Garden
DITTO!
Sure you lose some height but to me it's worth it because you can store things underneath of it. I throw a 30 lb bag of dog food underneath of it, and then put my groceries on top.
babyivan
Queens
The height is not an issue for me. If I need more, I just remove the decklid
XR650R
Eerie
Makes sense. Good to have options.
D
Pittsburgh, PA, USA
Thread Starter #18
Are there any other “easter egg” type things about the ST that people might not know? Mine didn’t come with a manual, so I’m not up to par with anything.
babyivan
Queens
As promised, my trunk setup.
Got everything I need: A container of the most essential tools. Air compressor. Cleaning stuff in another container. Tarp. Flashlight. Oil filter. Bungees. And a bunch of other little odds and ends.
The 3rd pic is of a folding shovel I found at walmart. Probably won't do much for major heavy snow, as it's aluminum, but it'll do an emergency.
The 4th pic is of these book end looking things with Velcro on the bottom (also found at walmart). They are specially designed for hatchbacks. I use them when I buy a few items that don't fill the whole cargo area... keeps everything from flying around.
2017 Magnetic FiST w/Recaros
