Will a BOV adapter reduce intake valve carbon?
I recently installed an OCC on my new 2017 FiST and after just 1000 miles, I had accumulated maybe a couple of ounces. My question is whether the volume of air passing through the PCV valve (and into the OCC) will be reduced, along with a reduction of oil vapors, if I install a BOV adapter that allows boost to vent to the atmosphere, instead of venting into the crankcase with the OEM setup? Any thoughts?
The recirculation system is upstream of the PCV system, changing it wouldn't change the PCV flow. Also, the stock system recirculates back into the inlet side of the turbo, which does have a path into the valve cover but I don't think I'd call it venting into the crank case exactly.
Here's a thread that explains how the PCV flow works pretty well:
http://www.fiestast.org/forum/fiesta-st-performance/481-oil-catch-can.html
Bluedrank
Nope.
It sounds like you want a catch can with a VTA option like the damon motorsports one has. BOV will not do what you're thinking it does.
alexrex20
OCC won't reduce valve carbon either. just saying
How does it not reduce carbon? It's reduces oil blowing through and introducing cleaner air into the intake.
Nope.
Or you could also get a vent to atmosphere oil cap...I have one...with a one way check valve....works pretty slick.
There are 2 paths from the crank case into the intake track, one to the intake tube before the turbo and one at the intake manifold. Most of the PCV flow happens under manifold vacuum on that second path. The only time PCV flow going into that first path is under boost and if you're under boost, the BOV would be closed most of that time anyway.
So, yes, you could vent a very small amount of the PCV flow out of a blow off valve in the short time between the BOV opening and the manifold pressure dropping into vacuum but in practice, the majority of the PCV flow goes either directly into the manifold or into the turbo's inlet while it's producing boost.
I was referring to Alerex20s post....
apex1
The reason for my original post in this thread is as follows. Whenunder high levels of boost and you lift your foot off the throttle, the boost pressure is vented. In the stock set up, it is vented through the diverter valve into the crankcase. So there is a blast of pressurized air into the crankcase. Where does it go? Does it cause a puff of air that has picked up oil vapors to vent through the PCV valve? I do not know the answer, which is why I pose the question. If the answer is yes, would venting to the atmosphere prevent that? Perhaps the answer is no. But that is why I asked the question.
That's not how it works though. Someone else already mentioned it. It vents to your intake, after the maf, before the turbo. Not your crank case.
Sent from my SM-G930W8 using Tapatalk
^^^Yes, I HOPE this is how it actually works, as I do NOT want that much extra pressure introduced into the crankcase, which has too much pressure already for my tastes. ;)
Quisp
No hope needed.
