Boomba Racing Catch Cans
Trader history for Boomba Racing (0)
lessard.dcj
Petawawa
[MENTION=1045]Boomba Racing[/MENTION], lots of space for a Water/meth jug of sorts to go with a TB spacer where the old intake box was. wink wink[coolsmile]
stuntdoogie
NYC
looks good, just be careful of the line, it will suck itself flat when not on the gas as I have learned from many other hose alternatives
I found the same clear hose at home depot, one is 3/4"od 5/8" id 30psi and the other 7/8"od 5/8" id 40psi. Are these sufficient or should I search for higher psi tubing?
airjor13
Centreville
Yep, you are SO RIGHT, those hoses collapse. I went to Napa and got some reinforced rubber hose for about $2 per ft LOL. Okay FINALLY completed!
Thanks again for the looking out Lessard!
lessard.dcj
Petawawa
the + psi is not the issue its the vacuum the line goes under will collapse it. round when on the gas and flat when off it. keep an eye on it after its warm. when you get home look at the line while the car is still idling. if all is well you'll be fine. what [MENTION=382]airjor13[/MENTION] is using is what i had as my entire hose. it didnt work out well enough for me. but a small piece may be fine
[MENTION=96]stuntdoogie[/MENTION]
airjor13
Centreville
This might be kind of dumb, but can you confirm if this is correct. Can you confirm [MENTION=1045]Boomba Racing[/MENTION]
PCV (Back of the motor) go into the IN fitting on the can
OUT fitting on the can going into the intake manifold correct?
Columbia
That's correct.
stuntdoogie
NYC
ok so here is my set up. sorry it's late. i dont have the factory hoses any more since i tried my hand at a HomeDepot OCC last year. so i did have this red hose i bought from TSC. i ended up pulling the oring off the reducer as it wasnt needed in the new red hose.
No need to clamp the hose on the ends?
lessard.dcj
Petawawa
i used heater hose. the stuff i tried didn't work. it flattened out. good luck on the stuff you bought.
KKaWing
Somewhere
Slightly random but 5/8" hoses are used by gas pumps too (at least around here). If anything is chemical resistant...
stuntdoogie
NYC
i was using it to replace my entire pvc hose. it flattened like a pancake. like [MENTION=382]airjor13[/MENTION] found out with his. yours may work though. fingers crossed
I see...since im only using about 6" of the tube it should be sturdier?
