Sirius not starting when turning on car
Half the time when I turn on my car after it was playing sat radio the radio will not play. I have to change to another input then back to Sirius to get it to work. Anyone else have this issue?
CANBUS must be intermittently reading the sat rad module. It is likely faulty or there is a known software issue. Dealer can fix you up either way.
I have the same problem. I just press the power button off then back on and it works as normal. Mine used to also just cut out while driving and play nothing until I turned it off then back on. Took it to my dealer and they reset everything and checked for updates, none were available. The reset fixed the cutting out while driving but it still doesn't work at least 50% of the time at start up. When I took it back to the dealer they said that they could not replicate the issue(of corse) so they could do nothing for me. They told me to take some videos when it happens and try to bring the car in when it's doing it but I haven't bothered to take it back.
Try resetring whole Sync system. Pull a fuse for 15sec and plug it back it. If its software issue this should help u.
MegaBuster
Only issues with the sat radio not starting. I have a 2015 fiesta st which is sync my ford touch i think
I have same thing half the time it works the other half I just tune to another source fm am or phone and back to sirius and it's fixed
