Noticed a small leak coming from the Oil cooler fitting so I took it apart again, this time removed the hood latch bracket so I could remove and properly torque the fittings. Hopefully this does the trick.
Installed my Mishimoto Oil Catch Can. Had to trim one of the PVC lines about 1/4 in but other wise fit right in.
Off-roading
Took it to a lot usually reserved for trucks, dirt bikes, and ATVs.
Mud, sand, mild rock-climbing, sideways dirt action. Mostly stayed on the smoother dirt, really otherwise my dental bill would skyrocket.
I never trash on the FiST, certainly didn't come close to it today, took it slow, especially on the uphills and descents, but you got to feed the FiST some rally otherwise it gets a bit cranky.
Waxing and sealant applications did an admirable job at shedding the splash, still deserves another good detail though, meaning wheels off and lifted so I can get to the underbody, especially because of the mud.
I know this does not look that steep, but scroll to the next pic... same hill in the background.
[/URL][/IMG]
I received delivery of my new wheels.
17x7.5", et42 and weigh in at exactly 16.4 pounds.
I know this is an old post did you have to run a hub spacer? Thinking about getting these wheels and running 215/40 tires just trying to make sure they fit good before buying. Thanks
MPA
Installed a Boomba transmission adapter plate. I'll have to drive with it a bit - not sure I like it.
Deli
Installed my TB Performance torsion and traction bars. [emoji1]
Where'd you get that from, pretty slick.
It was on Amazon. Cost like $7. The quality isn't that great but looks nice enough for the price.
I put my boomba bov spacer on my 16. It makes me smile and is comically loud
Finished my twin 12" sub install. Floor is only 3/8" higher! And can hold 200+ pounds.
Tire rotation and Oil change today. Went with Amsoil synthetic 5w-20 and an Amsoil filter. Then cleaned the wheels and what not.
LT Berzerker
Brakes changed out - right rear pins had a touch of pitting/nearly froze - cleaned them up and the bracket... Funny that there were no faults in the rubber boots... And oil change complete :)
Rear pads after 46k in 2yrs and 2 autox events.
dyn085
Swapped back to my OEM wheels with the S.drives Friday, then aligned today.
Finally got my bulbs, splitter, and rear torsion beam stiffener installed. Pretty happy even though it took most of my afternoon to figure out why one of my headlights still had hyperblink (the colored wires were seemingly chosen randomly on my passenger side, had to look at a pin diagram to figure out where I needed to splice in).
