So I tried to do some more swapping around of upholdstry and seat backs for a different look to better match my 2017 interior. Come to find out that even using the Fiesta recaro base, my Focus Recaros are a different back with different, wider attachment points. Im going to try and spend some time tracking down why this is, maybe I got ST1 Focus Recaros? Only thing I can think of when it comes to this. While some Focus Recaros do work for this swap, I can confirm 100% that NOT ALL FOCUS ST RECAROS WILL WORK IN THIS SWAP! Ive seen people claiming in this thread that they are the same. Be advised that some might be, but not all are.
What I can tell you about my Focus Recaros is that the airbag was not in a nice square plastic box like the Fiesta or the Ford Racing Recaros swapped by Zero. It was basically just wrapped up around itslef with the firing charge. I dont know if that means it is an early model ST1 Recaro or what, but its the one of the differences I found between my working Fiesta Recaros, the Ford Racing Recaros Zero got and the Focus Recaros that I bought. The other difference is of course that the seat back of the Focus Recaro is different, the attachment points coming off the seat back are wider than those on my non recaro Fiesta base and also the recaro Fiesta base.
Best I got right now guys, hope this keeps someone else from jumping in headstrong like I did or at least is aware of what you are getting into when you pull the trigger.
