After making the 3 season room and installing cove lighting in it I had lots of LED strip light that is powered off 12 Vdc. I decided to add some under hood lighting so I can see when I work in the dark (winter), checking oil, windshield fluid, find the block heater plug etc.. The stuff I got is waterproof and works at low temperatures. Can easily be found on ebay, actually everything I used today was off ebay.
Plunger switch to allow the lights to turn on only when the hood is lifted and unlocked from the cabin. This is great as it is now easy to navigate when there is no light. I installed it on one of the bolts by the hood latch. Is it was meant to be I think
Fished the ground wire following the hood release cable (under the headlight) and then the washer fluid lines. Tie wrapped with black ties every 6 inches of so. The whit line where the light should be is a clothes hanger I used to fish the wire.
For the positive I taped off an always on source. In this case the signal light fuse. I added a 3amp fuse for the led lights (they draw less than 500ma)
The strips have a adhesive backing for easy install. You must really clean the paint surface to get rid of any oils or other contaminants or it will not stick. You can also see I tied the wires to the washer hose and then fed it behind the liner to keep it clean. Not too impressive during the day.
Now the money shot. The camera flash is off and the cheap cell phone is crap at night. But I can see EVERYTHING under the hood. Even used it to plug the headlight in as I forgot. This was more of a, can I do it project, but I am really happy I did and it turned out well..
