This is my plan as of now, Map Intake,Cp-e IC, Tune+ and plugs, Cobb CBE, Pierce Street kit, CP-e RMM, Cp-e charge pipes for when it's time for Meth, TTR engine mounts, Boomba STS and bushings, GFB DV+, Powerflex suspension bushings, and I'm thinking the MeisterR but leaning more to B14's. I honestly would love to throw a set of MCS's on but they don't have them for the FiST
I could get some custom made but $$$$.
I plan to get my tune and plugs, then do some pulls and see how the car feels. I want to at least put on the IC pretty early as I'm sure it sucks as bad as the FoST does. I'm not sure how much I will do before a Hybrid turbo but a DP was thought of. I will go over that with Adam when I get my tune. There is some things in the works with this and the X-37 is most likely. The C39 seems like a good option but too early to tell. There was also talk of a X-37+ but that may not pull through. Then you have another step beyond all those which would be the MRX from Mountune. If they mimic the MRX FoST kit, I will most likely go this route except that kit already uses the smallest EFR and our engines are too small unless we utilize and extended redline to counter. Basically I'm looking to keep the powerband between 3000-7000 and at least 260whp on 93 but 300 would be ideal. With a Turbo swap I would only go this route if 330-350whp was possible and response was not over 3500. I stay in low gears when I drive, but when your mountain carving a thick linier power band is ideal
I usually research cars for a while, like 2 years lol. My last 2 vehicles I followed a while before they came out. I was down the same road with the RS but never anticipated this huge of a delay. I knew it was going to be bad, but nothing like it is
. My mods I listed are basically from 1 week of searching so any input would be great
I FULLY agree with spending twice as much for one of the best engineered, highest build quality ICs (the CP-E, which I AM going to get), over the half the price 'bargains' most do.
.But I plan on going Stratified for both a canned/flash tune initially, and then a full custom tune once the IC and boomba BOV are on the car.
IF I ever go cyborg 39 (or above that if Bryan ever releases the 'experimental' stuff he's working on), either Alex at Strat, or DHM are going to custom tune the thing.
I WILL get at least one set of summer street only wheels/tires even BEFORE any suspension mods (save for Powerflex bushings and aftermarket sway bar endlinks), and they will probably NOT be the lightest things on the planet
(Pro Race 1.2s in either 16x7 or 17x8 with 215/45s or 215/40s on them).With a dedicated set of pure winter wheels/tires next late summer, and maybe a set of the lightest 15" track setup I can find without doing the PIA 4x100 conversion with 225/45s on them, once I do lower the car some.
![Smile [:)] [:)]](/images/smilies/smile.png)
![Big Grin [biggrin] [biggrin]](/images/smilies/biggrin.gif)
