Firestone Firehawk Indy 500
Waterfan
#41
You're going to love these man, today was dry and I did not spin in 1/2. Super impressed!
Wait, you have full bolt-ons and protuned X37 and NO SPIN in 1 or 2? No feathering? That almost defies belief :)
Waterfan
#43
I don't believe it. All I have is a tune and still spin in 1 and 2, not as much, but spin is still there
His alignment might be perfect and 6 pt brace could be helping more than we imagine, but yeah.
Might not have the "donkey punch of torque" at ~3k like we do. But most X37 graphs I have seen mimics the sub-4k torque curve of stage 1/2/3 (and then keeps building to mid-6 when we poop out at ~5.).
#44
Not sure I believe it either, but he also has larger diameter tires, which reduces the gear ratio and force being applied, so less likely to slip. Probably only a couple percent difference though.
WeTheNorth
#45
Lol I do not feather my car ever, tires are much much stickier in every situation vs the sc2's I had prior. FYI here you can get rain and sunshine in a matter of hours. I see 20psi@2800rmp
It slipped today in 1st and not in second but remember I'm also pushing ALOT more power than most. And I am protuned, what the stock turbo does is give you a couple seconds of 'burst of power' I'm seeing 255whp@5500 and beyond ATM with the max boost set @24
Yes gear ratio is extended higher up on the rpm, so not sure what you're referring to. Also depends on the driver, not everyone launches the same. I have no need to exaggerate on what I have and how it performs.
#46
^^^Does your pro tune have Alex's latest Cobb enabled, timing based, traction control??
Zak757
Thread Starter #48
If I'm pushing around 220whp on the stock "donkey punch" turbo, are these tires in 205 width going to be sufficient? I'd go with these in a heartbeat if they came in more interesting sizes like 215/40/17 or 225/45/16, like the Dunlop ZII Star Specs do.
EDIT: 210whp
BronxBomber
#49
Nope, that function is not good. It's way to intrusive. I would much rather have control over my throttle 0-100% but ED!
I'm not much of a fan either, but you do know you can adjust the level of slip yourself right?
WeTheNorth
#50
Hmm 220whp on the stock turbo? I would like to hear about you mods currently. And I have been running these for a couple weeks now. Here are my impressions.
In the dry: they grip, my bfg sc2's can't even touch these in dry grip. When I take off, they just bite the pavement and I'm gone.
Wet: I have pushed the car quite a bit in the wet and they have been quite confidence inspiring. You can never go full tard In the wet, we do get A LOT of rain here, they
hydroplane a tiny bit but that's with A LOT of water on the ground.
Verdict: go BUY a pair, now.
Must be referring to a more recent update?
BronxBomber
#51
If you go to Tune on your AP, then select Adjustments then you'll have the option to Change CCF Traction Control. There are 8 levels of adjustment. You can dial in different amounts of slip. You can also select to have it active on only certain map slots.
Zak757
Thread Starter #52
Sorry, meant to type 210whp. Just an MR230 tune on 94 octane, dyno'd at sea level.
WeTheNorth
#54
Ok lets go back to topic
Thread is totally on topic, it's good to
Share power figures on cars so we can see how these tires perform on car A vs car B
So not understanding where you are coming from
Zak757
Thread Starter #55
I looked up Bridgestones AU website, and the Potenza RE003 comes in our OE size as well as 215/40/17. Either way, a better fit than any of the current available 17" sizes. I wonder why the Indy 500 doesn't come in these sizes, considering it's literally the same tire.
WeTheNorth
#56
They are seeing what the market does most likely
#57
Same here, even a 215/45-16 would be cool on a 16x7.
Azov
#58
I just finished a set of these. I've done 15k miles of hard driving including a trip to the dragon. They are currently discontinued now according to firestone. They handled pretty good, but I still liked the BFG Sport Comp-2s better. They were noisy and were no where near as good in the wet. I also felt like when I hit the limits of grip the BFGs were way more forgiving than these.
#59
Are you sure you don't mean the discontinued firestone wide oval indy 500 which are nothing like the firehawk indy 500? I almost made that mistake when looking for the firehawk indy 500's and found they are different by a large margin and not a lot of people seemed to like them
