Thread Starter
#401
- Member ID
- #5638
- Messages
- 4,003
- Likes
- 4,113
Thread Starter
#401
QUOTE=ron@whoosh;207561]good point^ and thanks
I have the option to buy 3 or 4 on the site and they are in stock
most guys replace the 3 towards the rear and leave the one by the DP stock since the engine does move a bit
then there are guys that replace all 4
please keep in mind these hangers DO NOT give at all so when installing the exhaust you have to make sure all clearances are good and you may have to make some adjustments to get everything right
but once you have everything installed and set with the poly, you're golden!
maybe we can start an official unofficial guide to using poly hangers outside of this thread?
each set up and application will differ based on if you are using a stock downpipe or aftermarket, etc
