Go-to setup for slightly more compliant ride?
I owned an ST until about a year ago, and I find I miss it quite a bit, so that I'm thinking about picking one up again. One thing that got to me after a while was that as a daily driver (which is all I use it for), it was a little too firm/crashy on the bad roads around here. I did run 15" wheels with snow tires in the winter, but I honestly didn't notice the smaller wheels make a big difference.
So if I get back into one, is there a generally recommended route that would ease up the ride a little bit? I don't want to lose all the sharp handling. But if stock is 10/10, maybe back it down to 8 or 9/10?
Just a little overwhelmed with all the options. I see Koni str.t, or coilovers set to softest setting, have been recommended. I would be more of a install it and forget it kind of person.
neeqness
Just curious, what size tires did you use on the 15s?
Capri to ST
It appears that the ride was softened up a bit starting with the 2016's.
I have a 16. If the earlier years were even more stiff that really is something. I think the stock suspension has way too much rebound. It is punishing on less than
smooth roads.
A
Yeah, I saw that mentioned here and there. Mine was a '15, I should drive a '16 to see if it feels different.
smooth roads.
I have found the extreme compression of the dampers to be the biggest issue. People have switched to Koni or Bilstein dampers and found the softer compression to make a huge difference in the ride...
KKaWing
The Bilstein B6 on stock springs is awesome. The dampers soak up the initial shock then follows the road.
BRGT350
The Ford Racing Fiesta lowering kit is actually pretty good and cheap. I ran it on my 2011 Fiesta and was very happy with it. The ride height was about the same as the ST, but the springs were a lower rate and the dampers were matched accordingly. I was able to drive the ST and my 2011 Fiesta back to back for 6 months and could really get an idea how the suspensions compared. Both were on 17" wheels and tires, so that took out that variable.
Capri to ST
smooth roads.
I would agree with what you said about the earlier years. I have not found my '16 way too stiff, maybe just a little bit, and I don't like overly harsh riding cars. I'll take the amount of stiffness mine has as a tradeoff for the extremely nimble handling, I think at this point they've balanced it pretty well.
I have Koni Sports and have found them to be much more compliant than the stock dampers. They are softer in compression and adjustable in rebound. Set them at 3/4 turn from full stiff front and rear and you'll have a very compliant street setup.
A
Thanks for all the input so far. I drove a '16 today, and I'd say it seemed pretty much the same ride as earlier years.
Just an observation. Temperatures in my area have finally started to warm up. I have noted that the ride is more compliant when the temp is 70 f and up. Going to guess it's the stock Bridgestone's. Not only do the road impacts seem more 'round' but the grip level is up. Still going to make some suspension changes.
Waterfan
OEM dampers are the major culprit to ride harshness. Especially the rears. As you noted, larger aspect ratio tires do help (45 or 50 series, etc. vs. 40) and the type of tire will help with comfort as well (all-seasons will be more comfortable than performance tires - and snow tires too, probably).
Waterfan
Stock Bridgestones "hate" temps lower than 50F, IMO. Noticeably less grip in cool temps and slightly harsher ride. I ran lower psi in cool temps so they would heat up faster (from ~40 to ~35)
neeqness
Just curious, how much psi do you drop yours for colder temps?
Edit: Don't mind me I was really tired when I posted this and for some reason thought the numbers in parenthesis were degrees Fahrenheit, lol
For craters, potholes and skillets, wider tires help. 215/45/R17 Continental
Suspension also seems to improve over time.
The roads are pretty bad, more especially during the Winter/Spring transition and have bottomed-out the front suspension twice in 14k.
Koni STR.Ts or Bilstein B6s are apparently the cure on stock springs.
KKaWing
B6 w/ '15 OEM springs ('17s went softer). The only major body movement is the double dip "squat" right before the left hander. Not sure how it translates in video but here ya go anyways.
[video=youtube;f3xbFtVnzls]https://www.youtube.com/watch?v=f3xbFtVnzls[/video]
