EDIT 24y05m09d: / 25y10m20d
Content updated under following thread...
https://www.fiestastforum.com/threads/abrasion-wear-on-coolant-line-other.32335/
https://www.fiestastforum.com/threads/abrasion-wear-on-coolant-line.32335/
/EDIT
I always inspect my vehicles during oil changes.
The following photo is a shot underneath the hood of a 2016. (purchased new, no servicing done)
Squared in red, there's a small-diameter hose, rubbing against an electrical plug.
It is not secured. It has not had a hole worn in it... yet?
What function does this line serve? It could be a vacuum line, but a vacuum line for what system?
If you find this hose underneath your hood, is it secured and is it routed identically ?
Have you secured or rerouted it?
Does it look like you are close to, or may have worn a hole in the line?
Any problems of note, if you have worn a hole, or worn it thin enough to collapse?
https://1drv.ms/i/s!AhsZJDCN8kMMi1lZ1vlcfpaen8h0
https://1drv.ms/i/s!AhsZJDCN8kMMi12Nk7qCiJmyivTh
Other unrelated things I noticed during my inspection.
* https://1drv.ms/i/s!AhsZJDCN8kMMi1qeYwfaTjDPAw7I (may be normal with brake rotor/pad wear - primary reservoir still full)
https://1drv.ms/i/s!AhsZJDCN8kMMi1y_W-dnQyv9XNQs
* With front on jack stands (not flat) coolant level right at MIN at ~70°F - level should be comfortably above MIN once vehicle is lowered/level
* Blower Motor (*not* engine fan) quit working after oil change. (pure coincidence)
BLOWER MOTOR
Fired up the vehicle after the oil change and noticed I no longer had any blower motor function; all indicators fine.
Reseating what I think may be the blower motor relay has seemed to resolve it for now.
Two things I noticed, there is no fuse center cover and, the wire harnesses don't have the typical OEM sheathing.
This car being new that leads me to ask, do you have a cover over your passenger compartment fuse & relay center and, do your wire harnesses look like below?
It is located behind the glove box. Simply squeeze the top-rear portion of the glove box to fold down for a look.
https://www.carcarekiosk.com/video/2011_Ford_Fiesta_S_1.6L_4_Cyl./fuse_interior/replace
https://1drv.ms/i/s!AhsZJDCN8kMMi1_mXlTAg_3t0ujz
https://1drv.ms/i/s!AhsZJDCN8kMMi2DGlVsZEiVMsXV7
Thanks.
/EDIT
BLOWER MOTOR
Thanks.
![Really Confused [???:)] [???:)]](/images/smilies/confused.gif)
