I recently bought my FiST, which was also the first brand new car I have purchased or owned and I decided I really wanted to get a good wash and wax on my new car, so I didn't have to worry to much about cleaning it as much. I haven't ever put much thought into how I washed cars, my first truck, a 1980 Chevy C10, got washed by hand, but without much thought, and definitely no waxing. As I got older and had more money and less time I just started taking my later cars to mechanical car washes. After recently refurbishing and completely stripping, priming, and painting a 1954 Willys CJ-3B I realized there is a lot about paint and paint maintenance I didn't know. And now with the internet, there is no reason not to know how to properly wash and maintain a paint/clear coat if you want to know. So, with a thirst for more knowledge to feed my recent Fiesta obsession, I started digging into how to wash and wax a car. And all I can say is wow, there is a TON of things I would have never considered. Just to summarize my findings in one spot and hopefully get some feedback here is what I found. This forum was a very good resource as usual, but it seemed like I could summarize some it in a single place.
I assume the Fiesta ST as most modern cars have a base coat, and then a clear coat on top. When we wash our cars we are really washing the clear coat, and when there are scratches or marks it should hopefully only be in the clear coat. With this in mind we are really washing and waxing the clear coat. My assumptions are the following, the wash/clay is to remove dirt and debris obviously, and the polish is to smooth out scratches in the clear coat, the wax or sealant is just to provide an extra layer of protection, make it shine, and fill in any left over scratches in the clear coat. There are also cleansers to remove any residual wax from previous wax coatings to get back to a base clear coat. I am obviously not a professional detailer but all that makes sense to me. So here is my current thoughts on a process I am going to use to wash and wax/seal my brand new Fiesta. I won't do this full process every time, maybe twice a year at most.
Washing the Car (Always work from top to bottom, and cleanest to dirtiest to avoid pushing dirt around and scratching the clear coat during the washing process. Keep a light touch, and only scrub when you have to, make sure whenever touching you have lubrication.)
I found this great link that describes many of the processes I used in detail. Some other great information comes from https://www.autogeekonline.net/forum and Ammo NYC.
Step 1: Rinse Car (with warm water if you got it) I did this with regular hose pressure.
Step 2: Foam cannon and let the foam sit on the car to soak into any dirt.
Step 3: Rinse car (this time I did it with my pressure washer, with the wand a couple feet a way at an angle) I figure the pressure washer would be able to push quite a bit of the soaped up dirt off on it's own.
Step 4: 2-Bucket wash with microfiber mit, use grit guards. I am thinking I might foam cannon the car again and then wash with the 2-bucket method. This would evenly distribute a nice layer of soap to keep track of where I have washed already.
Step 5: Rinse Car with sheeting method, use the full hose stream and run it over the car so the water sheets and doesn't leave as many drops.
Step 6: Blow dry, I have an 80V battery blower, others have recommended a heated filtered blower. Then hand dry with a waffle weave microfiber towel. I would probably use two, one to get most the water, the other to pick up the leftover. The waffle weave is to supposedly keep the dirt in the waffle holes, and off the clear coat. The AMMO video posted by pirite below, has a good section on how to dry using microfiber and some lubrication. This includes an interesting tip to dampen the microfiber to allow it to pick up more water. It also has a recommendation as with all things when touching the car to have a very light touch, and only touch it enough to remove the dirt or water, no back and forth scrubbing, and if necessary use running water to lubricate while scrubbing where scrubbing is necessary. Make sure everything is dry, you do not want water spots.
Added Step: Iron-X and rinse/rewash/dry to help remove an ferrous contaminants prior to the clay bar/mit.
Step 7: Clay Bar or Mitt with lube to remove any left over particles, and maybe wash again if you have the time. I was thinking that I might re-foam cannon one more time and hit the whole car with a clay mitt after the Iron X to save some time.
Step 8: Cleanser/Polisher like Klasse All-in-One, as I understand, this will clean off any more gunk and get to a bare clear coat, and also polish and provide some protection. Only need to do this once. I used the process described in this link. I used the manual method.
Step 9: Sealant like Klasse Sealant Glaze, this will add an extra layer of protection to the clear coat. I used two coats of Klasse Sealant Glaze spaced a week apart. I used the method described in this link. Also before applying any sealant or wax I applied 303 Aerospace Sealant on the trim and rubber. This was to help with any "overspray" from waxing. It seemed to help as I was able to just wipe off the white wax spots that I accidentally got on the trim.
Step 10: Carnauba Wax, this will add more protection, but will mostly just ad "depth" and shine. I used three coats of Collinite 845 spaced at least a week apart with a good wash prior to applying. I used the method described in this link. I went back and forth with a DA, and then up and and down. Then I went and wiped it with a microfiber foam pad. I waited about 40 minutes and wiped the residue with a microfiber towel. I realize this isn't a pure Carnauba wax, but I was looking for protection more than looks. I will probably apply another layer after every few washes.
Maintenance: Carry quick detailer spray and a microfiber cloth to clean up any bird droppings or bugs as soon as possible to avoid damage to the paint.
I'm sure I don't have all this right, but based on my research this is my currrent plan. If anyone has more advice or recommendations I would really appreciate it. Thanks.
..Hoping that our fragile paint will not be damaged by water high pressure...![Big Grin [:D] [:D]](/images/smilies/biggrin.png)
