Thread Starter
#421
pics of the morimoto 2stroke 2.0.
i just replaced one of the bulbs with a techmax bulb. side by side you can tell it’s bluer then the morimoto, but not by much imo. it’s essientally the same size as well, the heat sink might be .5-1mm wider, but it’s such a small difference, and there’s more then enough clearance in the housing that it doesn’t matter. the beam pattern looks better and there is less of the kaleidoscope effect. i’ll get a few pics tomorrow.
Also interesting, is that your aim seems slightly high maybe, I use other modern cars with projectors that I can see their cutoff height and try to mimic that, but they look a little better than mine with bent anti-glare caps at least!
