There are a few other threads on this but I figured I'd add a bit more detail and provide a fun read for members.
So today I installed the Hotchkis rear sway bar. As many know these have been around for a good while (years I believe) and were suddenly selling for $86 shipped and a member mentioned it and then suddenly Hotchkis sold a few dozen within a week as we all jumped on the bandwagon. Me myself I couldn't resist the deal, and despite naysayers talking about understeer and ruining the perfect stock suspension setup I bought one.
SWAY BAR THEORY 101
My theory here is that it's the down low suspension mods that make a difference. My rear torsion bar helped turn/traction feel so I assume this will do the same. Plus here's the thing, let's say this mod does cause the back end to slip out more - why does it do that? It does that because the driver is now dealing with a car that loses itself easier...the reason for that is that better turning feel might cause the driver to overcorrect when turning and therefore result in the back end sliding. So my belief here is that the bar changes the car, and the driver changes with it. The benefit is that the car feels tighter, but the driver must accommodate or that new confidence will result in disaster. For me, I prefer the car to be tighter and make the corrections myself, but I'm a purist.
All of that could be different from your opinion, which is fine.
PRICE
Again $86, though now they're $179 so I guess I got a deal. This was not a "second" - quality is perfect.
QUALITY
10/10 - perfect paint, fit, welds, everything. Bar is hollow. Packaging was overkill. You get stickers and even instructions and a warranty card.
INSTALL
You will need a lift or ramps or a pit; the car needs to be at normal driving height. You will need an assortment of 15mm and 19mm sockets/wrenches. I used a breaker bar to remove the stock shock bolts. Installs in 20 minutes, piece of cake even for the novice. I am lowered on Mountune springs BTW.
1. Get car up
2. Remove 15mm stock shock bolts, one per side
3. Push shock to the side while you work
4. Fit sway bar and use stock shock bolts to hold it in place - tighten hand tight as far as you can go. This aligns the bar so the other 4 bolts align correctly.
5. Use provided 19mm bolts/nuts to secure, two per side. When doing this step you'll see in the pictures how I used a magnet to grab the bolts from underneath and then pull them down into their holes. It's a tight area so this trick helped. Also when tightening these, you're in the same tight area and it's tough to grab the bolt so make sure you have an assortment of wrenches to get in that tight space.
6. Now remove stock shock bolts, re-install shock, and replace stock shock bolts, get everything nice and tight.
7. Apply your Hotchkis sticker somewhere and be happy, you just added 10 pounds to your car.
REVIEW
Well I haven't driven it yet, it was dinner time and my wife wanted sushi so off we went in the minivan. I'll post some thoughts next week after some spirited driving.
![Thumbs Up [thumb] [thumb]](/images/smilies/icon_smile_thumb.gif)
PICS
SWAY BAR THEORY 101
PRICE
QUALITY
INSTALL
1. Get car up
REVIEW
PICS
![Wink [wink] [wink]](/images/smilies/wink.gif)
