1st Mod for my 19 FiST
Crossville, AL, USA
Finally got around to adding a Boomba Racing rear motor mount took all of 30 minutes to do , hardest part was getting everything ready and getting it on ramps .
So from this
To this
I haven't had a chance to test it out yet but I'll let you all know how it is after my trip to work and home later this evening .
F
Crossville, AL, USA
Thread Starter #2
Okay , here we go . The vibrations are extremely more noticeable from 1st to 2nd it's almost like the car is gonna shake apart but once I get into the upper gears it's has very minimal vibrations even with the a/c on. But Boomba has on the installation paper that it could take up to 1000 miles to get it broke in . Which I don't see how that super hard material gets broke in unless is wallows out a little since it's not really flexible . But the car just has 400 miles on it so I guess I'll know something about time for it's 1st oil change at 5000 miles . But I like the stiffness when shifting into gear and when I step on the gas you can tell it's not springy like with the old mount . :cool:
Pleasant Garden
Hey if you don't like it you can always try that whoosh rear motor mount out. I installed mine Sunday I don't even notice the vibrations. I made a video about it.
F
Crossville, AL, USA
ok, I'll keep that in mind, The FiST big brother my 07 Focus has a rmm similar to this Boomba so I'm used to having a lot of vibration that will rattle your teeth . So the FiST doesn't seem that bad .
XR650R
Eerie
I have the mountune rmm installed. I don’t notice vibrations . Another option for u.
+1 on the mountune. Very little vibration, and it gets smoother over time. The Whoosh is new, but it looks very similar.
Earth
My experience with the Mountune is great from a vibration perspective (almost none) and shifts feel much more direct. Unfortunately, it makes an awful creaking noise at low speeds. I guess I need to reinstall it with more lithium grease. I've always heard that urethane bushings are prone to squeaking and creaking and that's what I am getting right now.
XR650R
Eerie
Yeah. Mine came with 2 packages of grease. Use a lot.
Spork1569
Fillmore, CA
I have that same exact issue. Noticed it one day while leaving work and it seems to go away once the car warms up. Only happens just as I'm getting into gear so I was scared it was a tranny or clutch issue.
Maybe if I have free time this weekend I'll get under there and smear all the bushings with grease again, maybe that's the reason for all the noise is the polyethylene rubbing the washers the wrong way.
