Sirius antenna
Minnesota
I’m removing the ugly black box from my roof. I do not listen to the radio nor Sirius for a long time. Just a heads up, the Sirius antenna transmits your location even if your subscription has run out.
MRX330
Minnesota
Ford can see your car. Miss some payments and the repo man knows where it is. Collecting data? Who knows but the antenna looks terrible anyway. Bye bye
U.S. Navy Veteran
SFV, So.Cal.
A mobile phone can broadcast via data or wifi connections. How does a radio receiver perform that action?
DEss
As stated, it works like your phone or like LoJack.
The Sirius radio does transmit location info. even if not activated.
This info. could be used for stolen car location however you would need the radio serial number and Sirius would have to track it.
You can look it up on the infoweb.
MRX330
Minnesota
For now a plug with some sealant like the license plate plugs. I have some scratches on the roof so eventually I’ll have someone fix all that and the hole
MRX330
Minnesota
You have to take off the dome light and pull down the headliner to get at it
PunkST
Menasha
Its a square hole. Had mine off a couple times. Does your car have nav?if so id willingly take your active antenna. Still trying to fix my nav. Lol.
PunkST
Menasha
Dang... Oh well. To unplug it youre going to have to pull the rear c pillar trims, back door mouldings across the top ( rubber ones) and drop the rear section headliner carefully so you dont kink it.
