Big turbo car blue smoke at idle
Dyer, IN, USA
2019 fiesta at whoosh hyrbid turbo, car has 9000 miles and turbo has 1300 ish, the car at idle when hot will blow blue smoke at idle like at a stop light, it’s doing it about once a week and today it did it twice in a row. It’s really stated to freak me out because it’s either the turbo or the pcv system “i have a catch can” but besides that i don’t have a clue it did throw a P219a code, back when i picked the car up after install “BTR did it” and yesterday after it got dynoed and made 290whp. Car is running great but I’d love to figure this out
Yes i did switch to 5w-40 to try and help it
No smoke when accelerating or if it is smoking if i rev it, it doesn’t shoot a big ass cloud it’s just right at idle
any idea guys thanks
Pleasant Garden
Like I mentioned before if you had a catted downpipe you probably wouldn't even see the smoke.
Blue smoke equals oil are you having to add any oil?
You have a hybrid turbo not a big turbo big difference. You would get better responses if you listed the question as hybrid turbo.
San Jose
Empty the catch can and see if it goes away?
Otherwise it’s likely due to a lack of cats as mentioned above. Has the engine been using oil?
Gogoggansgo
Dyer, IN, USA
im going to check in about 5 mins i just changed it a few weeks ago i checked it last week no oil consumption
Gogoggansgo
Dyer, IN, USA
I was told flat out by blood type racing this a pretty common issue and if it was the turbo it would do it everywhere and at wot, part throttle you name it. I wonder if it’s a pcv issue
Gogoggansgo
Dyer, IN, USA
it does sometimes come out gray but it’s oil it smells like crap lol
Pleasant Garden
Just keep a eye on the oil level.
Sometimes if you really do have a problem you just have to give it time for it to show itself.
When you don't have a cat there's nothing to slow down / burn up that smoke. I'm not too concerned because you say it doesn't happen during acceleration.
Se7eN
San Juan, Puerto Rico
does your catch-can have a check valve? I had the same sort of problem when I first went to a turbo change, but had no check valve. Put on a UPR valve and problem solved.
Gogoggansgo
Dyer, IN, USA
it’s a diamond unit but that’s a good idea i ran them on my coyote
Se7eN
And if it was a bad turbo seal it would be getting worst and you could see the garage
My buddy is running that same turbo. He also has a check valve on his catch-can and has no smoking issue. It did smoke a bit when first installed while it all just burned off the shipping oil/lube that tends to be used. Both his car and mine are cat-less and have zero smoke.
Gogoggansgo
Dyer, IN, USA
Thread Starter #20
im wondering if the check valve, or catch can was plug in backwards
