DV+ compressor surge
NANAIMO
Hey guys, my DV+ is having issues with flutter and compressor surge. I was wondering what people did to rectify the situation, I've read that greasing the piston can cause it to stick but I'm not sure.
Sent from my SM-G960W using Tapatalk
They need to be oiled every so often from what I remember or they won't operate properly. There is a video on it somewhere...
JDG
Conshohocken, PA
I use 5w-20 engine oil on mine. No issues yet after doing that every 10k miles or so.
Clint Beastwood
Laguna beach
Do you have a catch can? The dv+ is *supposed* to get lubrications from blow by but in my experience you have to lube it occasionally. The fist dv is hard enough to get to that I went with a turbo smart em vr2 instead - same perks as the dv+ but no oiling ever.
C
NANAIMO
I bought it used off of a fella on here, he sold it because of the oiling and access issues and now that I've had to install this thing three times I completely understand why he got rid of it. It's in a terrible spot and is super fiddly. He used with lithium grease on the plunger, springs, and brass body. I'm gonna try to remove all the white grease and try motor oil and see if that prevents the fluttering. What about oiling the plunger? People online say not to do it as it can cause fluttering.
JDG
Conshohocken, PA
The white lithium grease was likely too thick. I would get that grease out and put motor oil on the brass piston. Make sure the plunger still moves OK. It shouldn't need much lubrication as I believe it has a large clearance fit. When you take the DV+ apart, check for scoring on the brass piston.
Clint Beastwood
Laguna beach
yeah the lithium is going to gunk it up, clean it with a silicone safe solvent then lube with motor oil. It doesn’t take much. Also maybe look up gfb’s “how to spot a fake” document to make sure yours is real.
C
NANAIMO
Thanks guys, I think you're right about the grease being the problem. He said he compared to the video when he bought it and it was legit, I've had a look as well and it seems to be genuine.
Clint Beastwood
Laguna beach
The piston should fit so snugly that when you let it go and "drop it" into the body of the DV, it should hiss slowly and sink slowly down. Most of the crappy knockoff ones fall straight in or bind on the way.
Chino Hills
Personally I will never purchase another used DV on this forum again, I got scammed by another member on here by the name of Blackbird. People can easily take another picture from Google and Photoshop in a piece of paper with their forum name. It happened to me, took me almost 6 months to figure it all out. Just my 2 ¢. He was also a well known member on here earlier during it's infancy.
Sent from my moto g(6) using Tapatalk
DangerMouse
Illinois
I use Lucas assembly lube. It was recommended when I had a cobb bpv on my mazdaspeed3 years ago. I used it on the gfb and it's been about 20,000 miles now, no issues. It is on my list of things to do this spring but for now its working just fine.
kivnul
U.S. Army Veteran
Deer Park, WA
I use a very thin film of moly grease. I don’t think it has caused any problems but I’ll swap to oil next time.
C
NANAIMO
So I took it apart, again, removed all the white lithium and applied motor oil. The plunger slides down slowly with a nice sshshh sound. Reinstalled and there is no surge at full boost, but on part throttle or under let's say 10 psi there sounds to be a bit of surge still there. When lifting off throttle it's kind of like PSHHHHtsutsutsu. How much flutter is normal on these? Buying a used one is such a crapshoot, I think its genuine and it looks to be well used but I'm not certain about the sound. It sounds like its improved but the surge isn't gone 100 percent. For example the stock BPV has zero flutter whatsoever. Thanks for the help fellas.
JDG
Conshohocken, PA
Is the helper spring installed? If so, some flutter is normal. And part throttle flutter is not to be concerned about.
Pleasant Garden
Some flutter especially on very light throttle is normal.
I have a turbosmart em bov.
C
NANAIMO
ill take a video and post it on here tonight. The brass piston had scoring on it , nothing too deep but noticeable.
Clint Beastwood
Laguna beach
the chrotling sound isn't abnormal, mine does it even stock. much more noticeable with a different DV installed though.
