So I took it apart, again, removed all the white lithium and applied motor oil. The plunger slides down slowly with a nice sshshh sound. Reinstalled and there is no surge at full boost, but on part throttle or under let's say 10 psi there sounds to be a bit of surge still there. When lifting off throttle it's kind of like PSHHHHtsutsutsu. How much flutter is normal on these? Buying a used one is such a crapshoot, I think its genuine and it looks to be well used but I'm not certain about the sound. It sounds like its improved but the surge isn't gone 100 percent. For example the stock BPV has zero flutter whatsoever. Thanks for the help fellas.
Sent from my SM-G960W using Tapatalk
