Thread Starter
#521
Lots going on right now in prep for reopening. I decided to build a chassis mounted splitter, which is requiring a lot of work since I don’t really have anything to go off of.
I started by removing the OEM air dam, my brake ducts and other trim that was in the way.
I also removed the Pierce 6 point (because it’s too low) and replaced it with a TB performance 4 point and traction bar. We cut, raised and rewelded the traction bar so it sits above the subframe. We also had to shorten the Whoosh charge pipe elbow and roll a new bead for the coupler so it would clear the new traction bar. It all worked very well and went pretty quick.
Creating a template for a 4” chassis mounted splitter took the majority of the day. We started with cardboard and moved to insulation foam since it’s easy to sculpt. That’s as far as we’ve gotten.. We’ll be back at it on Wednesday and hopefully have the finished splitter cut out of the 10mm Alumalite sheet. I’m making an air dam out of aluminum, which might not be the most practical material, but it’ll look bad ass when it’s finished. We will take the 4x8 aluminum sheet to a shop down the street that has a 10ft break. They’ll sheer and bend the sheet for us which will save a ton of time. It’s pretty thick stuff. The curves will be a fun challenge since we plan on using the old school metal shrinking method. I’ve never done that so I’m pretty excited to see how it goes. I’m gonna cry when I destroy it after sliding off the track but it’s totally worth the effort lol. This stuff is a lot of fun.
Here’s a few pics from today in no particular order. That IS NOT the final shape of the splitter. It needs an hour or so of finishing:
![Wink [wink] [wink]](/images/smilies/wink.gif)
