JDG Build Thread (S280 Turbo, Full E85, Custom Parts & Rallycross Discussion)
#41
From what I have seen, 17" wheels are the smallest diameter possible with the Megane 225 Calipers and 300mm SVT front rotors. Take a look at the clearances with 17's in these install videos:
View: https://www.youtube.com/watch?v=wUpL6ITt028&t=471s
View: https://www.youtube.com/watch?v=yTYqu10pZ_M
Even my kit, with 278mm rotors and the monoblock calipers, require a 3mm spacer with the dekagrams to clear the front face of the caliper. So your kit definitely won't work with the dekagrams.
My main question I guess is would it probably clear the inner barrel of the wheels. I could run a small spacer if need be. Just prefer not to.
JDG
JDG
Thread Starter #42
No, I don't think it will. But again this is just based on what I am seeing with my setup.
JDG
JDG
Thread Starter #43
Things are starting to kick again with the new, stiffer wastegate actuator. AEM 3.5 BAR MAP Sensor is due in Saturday so we can increase the boost past 28PSIG. Ambient temperatures in the low 80's here:
JDG
JDG
Thread Starter #44
New AEM 3.5 Bar MAP sensor installed. Ready for more boost!
Walked a couple of bolt on Subaru’s tonight during my datalogging session (2016 wrx fbo pump gas, 2007 sti fbo pump gas)
Felt good.
jeffreylyon
#48
Nice horsepower curve. I'm a little surprise to see you start to lean out with the 4-port.
JDG
JDG
Thread Starter #49
Not running out of fuel, still tuning. My aux fuel injectors will flow enough for 600whp lol.
xxiaze
#51
Felt good.
Yes man! Did you know them or stop and talk afterwards?
JDG
JDG
Thread Starter #54
Fixed my AC after 15 months without it (I damaged the high pressure line at the firewall installing my aux fuel). So happy to have it fixed. Looking forward to driving the Fiesta more this summer. Also, first rallycross of the season with my local SCCA region!!
