- Member ID
- #14889
- Messages
- 119
- Likes
- 121
Hi all, not sure if this belongs in the Engine Performance Upgrades section or not, but I am replacing my engine and transmission (and anything else that looks like it needs it while I'm at it) in a few weeks and I figured I'd ask if anybody has pulled their own engine out and if I should be on the lookout for anything while I'm in there. I have 145k miles on my 2014, and the transmission went kablooey (likely input shaft bearing judging by the noise it was making). When I checked the forums to see if anybody was selling a used trans instead of rebuilding mine, someone was selling an entire drivetrain out of a 22k mile 2015 (along with a crapload of other parts) and I couldn't resist. I figure mine was due for the coolant change and the timing belt replacement anyway, this is a good time to swap the whole shebang out for one with 120k fewer miles on it! My plan is to remove the hood, headlights, radiator and cowl, evacuate the AC system, unplug/disconnect everything and pull it out the top as one assembly. I'm guessing I can pull it with the downpipe attached and just disconnect the catback section. I have spares of everything now, and I'll swap my performance parts over to the new one while they're both out of the car. That's going to mean pulling the transmission off the engine and swapping over the flywheel and clutch, so I'll order new flywheel bolts and axle seals today (they're cheap, I don't want to do this again if I can avoid it). Anything else I should be looking at replacing while I've got it all apart? I'm hoping my V3 intercooler from @ron@whoosh might be here by then, but that's not the end all to install later. I have the new colder pregapped plugs to throw in the new engine, plus I'll swap over my upgraded mounts, CAI, etc. to the new one. I'll assess whether my existing radiator or the one I got from the other car is in better shape, same with axles (the CV joints on the newer one are bent kinda awkwardly to get them in the shipping crate, so I don't feel super confident about them). Overall, it *looks* like one of the simpler swaps I've seen, but if anybody would know about any hidden issues it would be this group.
Thanks!
John
Thanks!
John
![Frown [:(] [:(]](/images/smilies/frown.png)
