Isabella de la fiesta
Se7eN
Also, I wanna add, if any of you plan to do your clutch and never have done it with the engine in the car.... It is not a very easy thing to do. Don't do like me and try to complete it in 2 days... My fucking neck and back are killing me.
I've lowered the trans 2 times, on a lift and it was still a PITA cause I still had to do it basically on the floor to keep the engine supported.
R
Rocketst
Thread Starter #402
So the way I usually have done it had been the containers of fluid I buy have that small tube and I push that tube inside a silicon hose I have but that's why I was thinking funnel cuz I'll have to basically poor the stuff that comes out into a wider mouth. The funnels like 3 dollars though so it's worth a shot. I just hope 8 1/2 inches is enough.... Hehe
R
Rocketst
Thread Starter #403
Did you have help? Or were you alone like me? My wife refuses to help me lol. She says she's had enough of this car.
R
Rocketst
Thread Starter #404
Also none of my buddies had the day off. Shit still needed to get done
Invest in a transmission jack it will make your life much easier. I totally understand doing everything yourself, and the neck and back pain that goes with it. That's why I don't work in a shop anymore.
The easiest transmission I've ever dropped was a Nissan Maxima so much room.
I Bought a Motorcycle/ Transmissin jack at Vatozone for $12.00+tx on clearance...What a steal originally $179.00.:cool:. My future is so bright I gotta wear shades! [drummer]
I don't understand how you get so lucky with these deals who manages that darn AutoZone.
the duke
That's so cheap I"m dubious of it's safety.
They decided to quit carrying them....Put the tag out and should've pulled it but failed due to a lot of Slap nuts McDougal's working there.....I used to work for them...I know their hiring practices.
I will usually cruise through there once a month just looking for deals....Sunday mornings I have found the best deals. FYI.
Erick_V
Idk if you pulled the axle out yet but when I replaced my driver side I pissed fluid everywhere and luckily had an extra container of Ravenol on hand (always have an extra container of every fluid just in case). Cut the top of a gallon jug place it under the trans and catch the fluid and then you can put it back in and keep your floors clean 🤟🤟 wish I thought of that before hand but you live and learn lol
Se7eN
Had a friend help both times. But it was a real Pain still
R
Rocketst
Thread Starter #413
Alright guys, so the spec clutch AND pressure plate are shot. Stock clutch and flywheel went in yesterday as well as a fresh power pull to confirm it's happy and we are back in business. Gonna try having the fidanza flywheel resurfaced but may not be able to as it's a insert. I don't understand what causing the spring mounts in the pressure plate to break the studs... Also, the clutch is completely glazed now, no material to grab anything means there's no hope for it. Gonna see if spec has an explanation for any of this because even if I had the thing in backwards I don't understand why the damn pressure plate broke.
R
Rocketst
Thread Starter #415
Dude I did too. I though it was good no slips but 50 miles later it got so bad the car was almost undrivable. That pressure plate damage is brand new.
R
Rocketst
Thread Starter #417
Just to say, the car feels faster than these numbers. Kind of surprised me they are so low.
Se7eN
Are you logging just one gear? not letting it hit the limiter or going WOT on another gear? Vdyno does not like that
