Is it possible to Uninstall the Mountune Quick Shift kit?
Nanuet
I just bought this because i wanted to greatly reduce my throws. Maybe one day will get the coolerworx lever but it seems they dont pair well. So before i pull the factory ball out, has anyone ever successfully pressed the factory ball back in?
DangerMouse
Illinois
I did when i put the coolerworx in. You need to remove the whole unit from the top of the transmission. Make sure car is in neutral and wiggle it out. Then you can remove the mountune adapter. I used a deadblow hammer with the mountune pin puller as a holder for the stock pin.
V
Nanuet
Looks pretty involved but not terrible. Thanks.
So you didn't even try to see if it worked with the two combined?
Burlington, NC, USA
I've seen reports that you can't figure out what gear you're in nor can you find neutral with both. I have every intention of removing my Mountune adapter to fit a coolerworx in the future as well. Thanks for this post
DangerMouse
Illinois
It wasn’t too bad. I couldn’t get the assembly out at first, was a little timid and i didn’t want to break anything. I just wasn’t pulling hard enough. I did not try both the mountune and the coolerworx together. The coolerworx is perfect as is, I don’t think it needs to be any shorter.
