Has anyone installed an underseat enclosed subwoofer w/ amp? Not looking for anything loud just want a little more bass than the stock system offers. Thanks.
I just followed this guide two weeks ago, was a prefect guide to follow. I used the same Kenwood amp/sub combo and at the max setting it is just the right amount under the driver seat. if you want door rattling amounts of bass, try a different unit, but if you just want to add some bass to the factory system its perfect. I typically run it 3/4-full volume on the remote.
at the same time I also upgraded the door speakers/tweeters as my factory tweeters were cutting in and out, I ended up going with a Hertz component speakers (https://www.crutchfield.com/p_301K165/Hertz-K-165.html)
I ordered from Crutchfield and it came with the new adapter rings as well as the direct plug in harness adapters. it worked pretty well! overall it improved the system for about $330.
Yes, infinity basslink mini....super small and easily an underseat sub but I didn't want it there. Sounds really nice and adds the kick i was looking for. The LED on the volume knob is crazy bright so I mounted it inside the armrest so I wouldn't have to see it!
