Broken hose, autozone says it is the intake adapter but still not sure
Salt Lake City, UT, USA
This hose is broken connecting to my intercooler and cold air intake. I noticed it was broken after the intake fell off when I was driving. I am not sure if it correlates at all. It also gave me this code right after. Please help!!
B9D0A7B0-A58B-442E-AD4A-C00B7E1888D8.jpeg B295F63F-1206-4520-AA14-E48BFAF4D30D.jpeg 395C3AED-78B6-490D-BF3E-25E7AA085583.jpeg C3A17899-4010-4E28-A7FE-66A5526BCBB3.jpeg
Rocketst
Chesapeake, VA, USA
You should fix that because it'll mess with the maf readings and won't calculate the correct air flow readings and will mess up your fuel trims but that's not the reason that code is popping up. That code pops up when the tune has messed with the torque tables for the car and it's overshooting them. Talk with your tuner and see if theyll turn the p061a off for you.
Sent from my IN2019 using Tapatalk
Rocketst
Chesapeake, VA, USA
Thank you, do you by chance know what the hose is called?
To get that repaired, it looks as though the bung is broken. That hose is your cold side intercooler hose. The hose coming out of it, I'd need to see where it goes but it should be your EVAP purge valve but it doesn't look damaged in the pictures you provided.
Rocketst
Chesapeake, VA, USA
I think I see why your saying the hose is broken now, it took a minute looking at it. So your saying that the plastic on the bung is broken, I agree it looks crushed. Is this Cobbs solution or an OEM EVAP harness? Cuz it looks like one I've used before and I feel like it's Cobbs.
K
I believe the rust looking substance is the silicone previously used by the other owner to temporarily repair the crack but now the hose is completely broken.
5C2C6EAA-277D-4789-83F0-AB4E3123887F.png 863E1918-59B4-4971-871C-757874151165.jpeg
K
I believe it would be a cobb, i’m not sure. i just bought the car. the intake is a tuned injen
K
Now looking into it, this look like what it is underneath my hood. the bottom pink one is the one that is broken 937D0C94-53A1-4698-98F7-B3550A052791.png
Rocketst
Chesapeake, VA, USA
Since you have an aftermarket intake and just bought the car don't complicate it. Just order this. https://whoosh-motorsports.myshopif...-to-convert-2016-fiesta-st-to-2014-2015-specs I don't advocate specific vendors but ron's a really good guy. That is an OEM conversion to the earlier 2015 style EVAP harness. It's from ford but they stopped putting it in these cars and made a 2 piece harness that doesn't work with aftermarket intakes. This will replace the entire thing and work 100% I've been using mine for almost 3 years with no issues.
Rocketst
Chesapeake, VA, USA
When you get in there and do the repair, you may find that silicon is hiding more than it's letting on though, be prepared. You may need to buy a new cold side charge pipe if that bitch is cracked. It's made of cheap plastic but the aftermarket ones you can buy are aluminum so they'll be more sturdy. Unless you plan to just buy another OEM cold pipe
K
Okay, thank you for your help!
Sam4
West Chester, PA, USA
I've got to sat that looks like a job for tape. Black, vinyl, sticky tape. Duct, duck, electrical, Gorilla, Flex. Actually, just saw the Flex brand - that may do it for you!
Quite a few folks here probably have a spare OEM cold side pipe they may be willing to share.
I vote for New/ slightly used Coldside pipe and emission harness. What is the mileage at on this FiST?
FiestaSTdude
Cary, NC
I just got a P061A code after getting a tune, good to know it's not serious.
