Rear end / wheels not centered?
Santa Cruz, CA
So I just replaced the brakes on the new-to-me FiST I bought a few months ago. Pads, rotors, lines, fluid.
I also removed the cheapie shim spacers that were on the rear wheels.
When I got everything buttoned up today, I noticed that the rear wheels are not uniformly set in from the fender. I lined a straight edge against the wheel face, and got about 13mm to the fender on the passenger side, and only about 4 on the driver side.
Is there a way to fix this? Can I recenter the rear beam by un/re-bolting it? Is there any play in the way it mounts to offset it to one side or the other?
I'm attaching some shots of both sides, with measurements.
Passenger:
Driver:
mark_SC
Santa Cruz, CA
Thread Starter #2
Ok... to answer my own question - it seems that the rear beam is held in place by 3 bolts per side, and the hole is elongated.
From a Spark Plug Steve video:
Time to crawl back under the car and do the fiddly job of getting the damn thing centered.
FJ16
Wichita, KS, USA
If the wheels/tires are identical (I know, it would be strange if they weren't), then I would assume that either you have some alignment/camber issues in the rear, or someone used parts that are non-ST replacements.
Edit: Nevermind, looks like you found it.
Woods247
Atl
Mine gets tweaked every now and then. My alignment guy uses some crazy long tool to move it and realign the rear beam after loosening those bolts. I thought I was the only one that had this problem. I’ve knocked it way out after accidentally getting the passenger side off the ground.
mark_SC
Santa Cruz, CA
I was thinking about the one side thing. The way you have to jack this car up (one side at a time) to get jackstands under it puts a lot of strain side-to-side. If those bolts aren't super snug, I bet it could shift just from trying to get the car in the air. I really need a Quickjack!
Jabbit
New England
Sidenote - I have a quickjack and wish I'd just bought a 2 post lift. If you have the room, 2 post lift all day. Quickjack is decent but to me it's not any faster than a nice jack and jack stands.
Woods247
Atl
Glad you said this because I’ve been considering a QJ.
Jabbit
New England
You still have to lay down next to the car (each side), align each side, raise them until they get really close to the car, get down and align them again unless you got it spot on the first time (but how would you know unless you laid down to check), then lift all the way up. It is fractionally better than a jack/jackstands, but not $1,000 better. I'll be selling mine and swapping to a two post lift in the winter/spring. I originally was hesitant to go with a lift since I have small kids and my paranoia for danger/injury got the best of me. However I'm comfortable with the thought now. I realize not everyone has the space but that's what I'm looking to do. Let me know if you have more QJ questions, happy to answer.
