SLD Wilwood BBK - With SVT Caliper Brackets - Needs Consumables
Trader history for shouldbeasy (0)
shouldbeasy
Wilwood BBK - Front 6 Piston Calipers with brake lines. New slide pins, retaining clips, adapter rings - you just need to buy the brake pads and rotors of your choice and the hardware to bolt the rotors to the hats - I was going to change to an actual bolt and not a torx cap head to stop them from seizing inside (getting the hats off the old calipers sucked). SVT calipers are good to go as slide pins aren't seized - need some TLC.
$350 USD
USPS / Canada Post - $50 - Shipping from Calgary, AB
PM if interested
If you'd be willing to part out the SVT caliper bracket, I'd be interested in that.
the duke
BALLS THIS IS TEMPTING. Let me take a look at the spares, I might be willing to buy just the fronts.
shouldbeasy
shouldbeasy
not willing to part out currently.
Team up with @ztrahan and buy the lot!
LilPartyBox
Phew finally! That was too tempting
